You will learn everything about high voltage insulator functions, how breakdown occurs and testing high voltage circuits in lab. The course covers the concept and operation of HV testing transformer, cascaded and resonant HV transformers, TESLA coil, etc. After taking the course, you will have a clear picture of the main features of overhead line insulators, how to avoid flashover of the insulator, different tests to be made on the insulator and corona/sparkover effect in power engineering.
The course consists of 49 lessons and 5h 1m total length. Downloadable materials (PDF) are included.
The purpose of this course is to give you a thorough introduction to high voltage engineering and insulators to aid you in your profession, your studies, or even if you wish to begin your own scientific research in this area.
In this course you will learn the following:
- The importance and the need for high voltage
- The insulator function for isolation of H.V
- How breakdown occurs in insulator
- The meaning of dielectric strength of insulator
- Different applications of Using high voltage
- Different types of testing high voltages in lab
- The concept and operation of HV testing transformer
- The difference between HV testing transformer and Power transformer
- Cascaded HV transformers for higher voltage generation
- The operation of resonant transformer
- Everything about TESLA coil for high frequency HV generation
- Different applications of HVDC
- Van de Graaf generator for HVDC generation
- The concept of rectification for producing HVDC
- The operation of different rectification circuits for HVDC generation
- Impulse voltage waveform
- Marx circuit for producing lightening stroke in lab
- High voltage testing circuit in HV lab
- Precautions taken into consideration during the test
- Different methods to measure different types of high voltages
- What is the sphere gap method for measurements
- The effect of atmospheric conditions on the measurement
- The function of overhead lines insulators
- The main features of overhead line insulators
- Comparison between different insulator materials
- Pin insulator vs. Suspension insulator vs. Strain insulator
- Different causes of insulation failure
- How to avoid flashover of the insulator
- The function of arcing horns
- Different tests to be made on the insulator
- Voltage distribution across the insulator string
- Importance of using guard rings with the insulator
- The meaning of sparkover and how it can occur
- Everything about corona effect in power engineering
- Anyone having passion to learn high voltage branch of electrical engineering
- Electrical power engineering students
- HV engineers working in HV substations
- Commissioning engineers in the HV field
- Postgraduate electrical power engineers
- Basic principles of electrical engineering concepts (like voltage, current and power )
- Passion to learn about high voltage engineering
- Generation of Different Types of High Voltages (PDF)
- High Voltage Testing and Measurements (PDF)
- HV Phenomena (PDF)
- Overhead Lines Insulators (PDF)
- Energy transmission and distribution guide (PDF)
- Handbook on EHV overhead lines and underground cables (PDF)
Low Voltage Distribution and Lighting Design Bundle: AutoCAD, Dialux, Excel (Course + Coursebook)
Low Voltage Power Distribution Course For Beginners
Electrical Designing and Drafting Course (Part 2)
Mastering Transformer Vector Groups: Learn How To Analyze and Draw Windings Connections
Power System Analysis, Modelling, Load Flow and Fault Studies for True Engineers
Mastering Power Substations: Electrical Equipment, Busbar Schemes and Relay Protection
Gas-Insulated Switchgear Course: Design, Installation, Operation and Maintenance, Testing
Understanding the Concepts Behind Power System Reliability
A Detailed Course to Wave Energy Conversion For True Engineers: Theory and System Implementation
Learn How to Perform Calculations of Electrical Loads and Design the Protection System
Relay Control and Protection Bundle: Complete Relay Circuitry and Schematics (Five Courses)
Practical Course to Ring Main Unit and Medium Voltage Cables in Ring Power Distribution Systems
The Essentials of Capacitor Banks: Connections, Calculations and Relay Protection
Electrical Designing and Drafting Bundle (Two Courses)
Power Engineering Course: Relay Control and Protection For LV/MV/HV Switchgear
Generation and Measurements of High Voltage and Overhead Transmission Line Insulators
Course to Relay Circuitry and Understanding Control and Protection Schematics
MATLAB Simulations using Simulink for Power Electronics, Electric Motors, Generators and Solar
Complete Power Engineering Bundle (Six Courses)
Advanced Electrical Machines MasterClass: Examples, Industrial Applications and Troubleshooting
MATLAB/Simulink for Analog and Digital Electronics
Circuit Breaker Failure Protection Course: Function, CB Scheme/Trip Matrix and Various Busbar Schemes
