Relay Selection Guide
Costs of the energy
Power distribution systems serving industrial or commercial facilities represent a variety of costs to the owner. Obviously, the capital cost of the equipment is a concern, as is the cost of the energy which that power system delivers to the loads which convert electrical energy to a saleable product or service.
There are some less obvious costs – the cost or reliability, measured in products or services which cannot be sold because power is unavailable, or an even more illusive concept, the cost of quality, which relates to customer satisfaction.
Ultimately, as the designer of the system struggles with devising a system arrangement and choosing equipment, he must face the reality that no matter how clever he is, no matter how much redundancy he builds into the system, and no matter how much he pays for premium quality components, he simply cannot build a system which will never fail.
This is where system protection, and protective relays become important. If component failure is inevitable, then it is necessary to provide a means of detecting these failures. Better and faster protection afford a number of desirable attributes, all of which ultimately result in saving the owner of the system money through cost avoidance. When component distress is detected and corrected earlier, the damage associated with the failure is minimized, which results in lower repair costs (or even the ability to repair versus the need to replace). At the same time, faster and more sensitive detection of problems means that the cause of the problem can be corrected while it is still a minor problem, and before it escalates into a major catastrophe.
Title:Relay Selection Guide
Pages:38
Download:Please login first
Don't miss anything!
Powered by MailChimp
  1. sajjad
    Dec 25, 2010
    i like so much EEP
  2. sajjad
    Dec 25, 2010
    EEP supplies valuable engineering information
  3. [...] with oil level until it passes a magnetic switch which activates an alarm. The bottom float and relay cannot be activated by additional gas buildup. The float is located slightly below the top of the [...]
Leave a reply!
Engineering Trainings
Top EEP’s Technical Writers
Technical Categories
Moisture Effect On Insulation Of Generator
Moisture, which can enter the insulation of a generator or motor winding from damp air or which can enter the...
Glossary of Medium Voltage Switchgear Terms
This glossary was published originally by Schneider Electric and it is intended to cover the meaning of many common words...
Types of electrical power distribution systems
Electrical power is distribution either three wires or four wires (3 wire for phases and 1 wire for Neutral). Voltage...
Close
