Electrical motors, how they work
Welcome! This motor book will provide you with a wealth of information about electrical motors, how they work, what they can be used for, and so on. But before we delve into detailed explanations of the world of electrical motors, we should perhaps spare a brief thought for the purpose of these motors.
After all, motors are always designed to carry out specific tasks. As this is a Grundfos publication, it is only natural that we should pay special attention to motors used for pumps – although much of the information contained within these pages will benefit all those with an interest in electrical motors.
Standards for AC motors
IEC 60034-2 Efficiency standards
Several standards for testing electric machinery exist on a worldwide basis. For induction motors, the three most important ones are IEEE Standard 112, JEC 37 (Japan) and IEC 60034-2. The efficiency value obtained from the different testing standards can differ by several percent.
This seems in contradiction with the theoretical definition of the efficiency:
- η = power out / power in
- η = 1 – overall losses / power in
The losses in an induction motor are distributed as follows:
- Stator winding loss Pcu1 – approximately 40-45%
- Rotor winding loss – Pcu2 – approximately 15%
- Friction loss Pfric – approximately 10-15%
- Iron loss Pfe – approximately20%
- Stray loss Pstray – approximately 10%
The main difference between the standards is the way in which the fifth loss component stray loss (Pstray), the additional load losses, is treated.
Standards for the testing of motors
The testing of standard motors is described in IEC 60034-2. In the following paragraphs two different methods of testing motors are presented: The direct method and the indirect one .
IEC 60034 covers the so-called industrial motors . Requirements of domestic appliances are listed in IEC 60335, which specifies somewhat different (stricter) requirements of the motors . In addition to the tests of standard motors our laboratory also undertakes to test products integrating motor and pump .
In principle the thermal tests are the same, but the tests are carried out according to other standards . Small circulator pumps are for instance tested according to IEC 60335-2-51.
| Title: | Motor Book – Grundfos |
| Format: | |
| Size: | 16.57 MB |
| Pages: | 252 |
So grateful for this site, it is a minefield of valuable information that has helped me improve my technical skills in Electrical Engineering.
Thanks alot ,i realy gained very helpfull information from this EEP web site .
as an electric engineer i found what i was looking for several times when i was serching here .
Once again thank you very much.
best regards
Salem
Thanks for giving such a detaled technical information on Motors.
i want to learn more detile about electrical part of grandiose pump
What a special people you are EEP, I hail you
Love the pretty colors. As a result I pulled my broken well pump out of the ground and replaced it with a shiny new Grundfos. Not only did I learn about motors, I now have hot water and a flushable toilet. At work they started calling me “Bear” because I was squatting down and leaning against a tree in the woods to poop. Thank you EEP and Grundfos!
Thank you verymuch Sir,
I want to know that how an induction motor can be rewinded with approprite wire guage (SWG) and how it create megnetic field to run a motor smoothly with its max. capacity load. If we change wire swg , the motor runs on wrong load. How can we decide approprite wire swg according to its stater and rotor?
Thank you for EEP,
Thank you very much EEP.
Thanks for providing an excellent website. I want to download the book on motors titled, “Motor Book – Grundfos” but the link is not working. The link is not a PDF file as it should be. Can you please send me this download in my email or fix the link on the download page. I really appreciate your website. It is an excellent resource, and would be even better if those download links worked as intended.
Dear authors
I would like to thank you for this useful portal and its helpful contents. wish you good luck. hope you go on.
It may be due to my security settings (I don’t know) but I’m unable to to download most of the material on the site.
Regards,
excellent informations , useful for students and professional engineers, i only feel sorry for not having these e books earlier, it could save me a lot of time an efforts. Thanks and keep the good work
I COMPILE ALSO DATA ABOUT APPLICATIONS IN THE ENGINEERING
Thanks for uploading this portal..Easier to understand..Nice one
Dear Mrs/Mr
I would like to download a book entitled “Motor Book – Grundfos” from your site. However, it is not possible for me to do that for even others.
