Operating Characteristics Of Motor
Losses
The effective or useful power output supplied by the motor at the shaft end is lower than the power input absorbed by the motor from the power supply, i. e., the motor efficiency is always below 100%.
Guide To Specification of Electric Motors by WEG
Guide To Specification of Electric Motors by WEG (photo credit: dmaeuropa.com)
The difference between input and output represents the losses that are transformed into heat. This heat warms up the windings and therefore must be removed from the motor to avoid excessive temperature rise. This heat removal must be ensured for all types of motors.
In the automobile engine, for example, the heat generated by internal losses has to be removed from the engine block by water flow through radiator or by fan, in the case of air-cooled engines.
Heat dissipation
The heat generated by internal losses is dissipated to the ambient air through the external surface of the frame. In totally enclosed motors this dissipation is usually aided by a shaft mounted fan.
Good heat dissipation depends on:
  1. Efficiency of the ventilating system;
  2. Total heat dissipation area of the frame;
  3. Temperature difference between the external surface of the frame and the ambient air (text-ta).
A well designed ventilation system, as well as having an efficient fan capable of driving a large volume of air, must direct this air over the entire circumference of the frame to achieve the required heat exchange. A large volume of air is absolutely useless if it is allowed to spread out without dissipating the heat from the motor. The dissipation area must be as large as possible.
However, a motor with a very large frame require a very large cooling area and consequently will become too expensive, too heavy, and requires too much space for installation.
To obtain the largest possible area while at the same time keeping the size and weight to a minimum ( an economic requirement ), cooling fins are cast around the frame.
Internal drop in temperature
An efficient cooling system is one that is capable of dissipating the largest possible amount of heat through the smallest dissipation area. Therefore, it is necessary that the internal drop in temperature, shown in figure above, is minimized.
This means that a good heat transfer must take place from the inside to the outer surface of the motor.
Title:Guide To Specification of Electric Motors – WEG
Pages:68
  1. José Aular
    Jun 17, 2020
    Thanks for your big work. It’s very important.
  2. hesham
    Dec 01, 2016
    thanks for your wonderful work
  3. youssef
    Nov 29, 2015
    the heat problem is solved for superconductor motor
  4. Ravi
    Dec 23, 2014
    good
  5. Ravi
    Dec 23, 2014
    its very useful refresher for us engineers
nineteen  −  ten  =
