Home / Technical Articles / Electrical Thumb Rules You MUST Follow (5)
Electrical Thumb Rules You MUST Follow, part 5
Electrical Thumb Rules You MUST Follow, part 5 (photo by engineeringourfreedom.blogspot.com)
Continued from: Electrical Thumb Rules You MUST Follow (Part 4)
Eight rules to follow:
  1. Standard Size of Transformer (IEEE/ANSI 57.120)
  2. Standard Size of Motor (HP)
  3. Approximate RPM of Motor
  4. Motor Line Voltage
  5. Motor Starting Current
  6. Motor Starter
  7. Impedance of Transformer (As per IS 2026)
  8. Standard Size of Transformer
Single Phase TransformerThree Phase Transformer
5KVA, 10KVA, 15KVA, 25KVA, 37.5KVA, 50KVA, 75KVA, 100KVA, 167KVA, 250KVA, 333KVA, 500KVA, 833KVA, 1.25KVA, 1.66KVA, 2.5KVA, 3.33KVA, 5.0KVA, 6.6KVA, 8.3KVA, 10.0KVA, 12.5KVA, 16.6KVA, 20.8KVA, 25.0KVA, 33.33KVA3KVA, 5KVA, 9KVA, 15KVA, 30KVA, 45KVA, 75KVA, 112.5KVA, 150KVA, 225KVA, 300KVA, 500KVA, 750KVA, 1MVA, 1.5MVA, 2MVA, 2.5MVA, 3.7MVA, 5MVA, 7.5MVA, 10MVA, 12MVA, 15MVA, 20MVA, 25MVA, 30MVA, 37.5MVA, 50MVA, 60MVA, 75MVA, 100MVA
Go back to Rules ↑
Electrical Motor (HP)
1, 1.5, 2, 3, 5, 7.5, 10, 15, 20, 30, 40, 50, 60, 75, 100, 125, 150, 200, 250, 300, 400, 450, 500, 600, 700, 800, 900, 1000, 1250, 1250, 1500, 1750, 2000, 2250, 3000, 3500 and 4000
Go back to Rules ↑
HPRPM
< 10 HP750 RPM
10 HP to 30 HP>600 RPM
30 HP to 125 HP500 RPM
125 HP to 300 HP375 RPM
Go back to Rules ↑
Motor (KW)Line Voltage
< 250 KW>440 V (LV)
150 KW to 3000KW2.5 KV to 4.1 KV (HV)
200 KW to 3000KW3.3 KV to 7.2 KV (HV)
1000 KW to 1500KW6.6 KV to 13.8 KV (HV)
Go back to Rules ↑
SupplySize of MotorMax. Starting Current
1 Phase< 1 HP6 X Motor Full Load Current
1 Phase1 HP to 10 HP3 X Motor Full Load Current
3 Phase10 HP2 X Motor Full Load Current
3 Phase10 HP to 15 HP2 X Motor Full Load Current
3 Phase> 15 HP1.5 X Motor Full Load Current
Go back to Rules ↑
6. Motor Starter
StarterHP or KWStarting CurrentTorque
DOL<13 HP (11KW)7 X Full Load CurrentGood
Star-Delta13 HP to 48 HP3 X Full Load CurrentPoor
Auto TC> 48 HP (37 KW)4 X Full Load CurrentGood/ Average
VSD0.5 to 1.5 X Full Load CurrentExcellent
Motor > 2.2KW Should not connect direct to supply voltage if it is in Delta winding
Go back to Rules ↑
>MVA% Impedance
< 1 MVA5%
1 MVA to 2.5 MVA6%
2.5 MVA to 5 MVA7%
5 MVA to 7 MVA8%
7 MVA to 12 MVA9%
12 MVA to 30 MVA10%
> 30 MVA12.5%
Go back to Rules ↑
Standard Size of TransformerKVA
Power Transformer (Urban)3, 6, 8, 10, 16
Power Transformer (Rural)1, 1.6, 3.15, 5
Distribution Transformer25, 50, 63, 100, 250, 315, 400, 500, 630
Go back to Rules ↑
Jignesh Parmar
8 Comments
  1. Ajay
    Jun 05, 2021
    May be there is mistakenly written KVA ana mva of transformers.
  2. sangdeep walde
    Sep 24, 2015
    dear Mr.Jignesh,
    Good day,
    what did you think of applying negative sequence overcurrent relay(51Q) with zero time delay at incoming feeders in GIS substation of 230KV parallel line and after stepdown to 13.8KV applying in all outging feeders to all distribution transformers.
    confused in 51Q and 46/47 for negative sequence protection.
    Thanks and warm regards
  3. Joseph Auo
    Jul 08, 2015
    Dear Sir,
    It seems that Power Transformer Sizes mentioned are wrong. These should be in MVA.
    Please correct
    Joe Auo
  4. Ramakanta
    Nov 24, 2014
    Power Transformer (Urban) 3, 6, 8, 10, 16
    Power Transformer (Rural) 1, 1.6, 3.15, 5
    Distribution Transformer 25, 50, 63, 100, 250, 315, 400, 500, 630
    sir, I am confusing about Standard Size of Transformer – how Power Transformer less capacity than Distribution Transformer ???
  5. kamyar elyasi
    Jan 27, 2014
    thank you
  6. SYAMLAL
    Nov 23, 2013
    very usefull .thank you
  7. Ahmed Imam
    Nov 21, 2013
    It’s very good and quick reference
  8. deepakdj18
    Nov 21, 2013
    grt info jignesh……..thank you
Leave a Reply to Joseph Auo
  ×  one  =  7
