Development of an algorithm
The first step in developing a control program is the definition of the control task. The control task specifies what needs to be done and is defined by those who are involved in the operation of the machine or process.
The second step in control program development is to determine a control strategy, the sequence of processing steps that must occur within a program to produce the desired output control. This is also known as the development of an algorithm.
A set of guidelines should be followed during program organization and implementation in order to develop an organized system. Approach guidelines apply to two major types of projects: new applications and modernizations of existing equipment.
Flow charting can be used to plan a program after a written description has been developed. A flowchart is a pictorial representation of the process that records, analyzes, and communicates information, as well as defines the sequence of the process.
Logic gates or contact symbology are used to implement the logic sequences in a control program. Inputs and outputs marked with an “X” on a logic gate diagram represent real I/O.
- The I/O assignment table documents the names, locations, and descriptions of the real inputs and outputs.
- The internal address assignment table records the locations and descriptions of internal outputs, registers, timers, counters, and MCRs.
- The register address assignment tablelists all of the available PLC registers.
Special cases of input device programming include the program translation of normally closed input devices, fenced MCR circuits, circuits that allow bidirectional power flow, instantaneous timer contacts, and complicated logic rungs.
- The programming of contacts as normally open or normally closed depends on how they are required to operate in the logic program. In most cases, if a normally closed input device is required to act as a normally closed input, its reference address is programmed as normally open.
- Master control relays turn ON and OFF power to certain logic rungs. In a PLC program, an END MCR instruction must be placed after the last rung an MCR will control.
- PLCs do not allow bidirectional power flow, so all PLC rungs must be programmed to operate only in a forward path.
- PLCs do not provide instantaneous contacts; therefore, an internal output must be used to trap a timer that requires these contacts.
- Complicated logic rungs should be isolated from the other rungs during programming.
The benefits of modernizing a relay control system include greater reliability, less energy consumption, less space utilization, and greater flexibility.
Example Of Simple Start/Stop Motor Circuit
Figure 1 shows the wiring diagram for a three-phase motor and its corresponding three-wire control circuit, where the auxiliary contacts of the starter seal the start push button. To convert this circuit into a PLC program, first determine which control devices will be part of the PLC I/O system; these are the circled items in Figure 2. In this circuit, the start and stop push buttons (inputs) and the starter coil (output) will be part of the PLC system.
The starter coil’s auxiliary contacts will not be part of the system because an internal will be used to seal the coil, resulting in less wiring and fewer connections.
Table 1 shows the I/O address assignment, which uses the same addressing scheme as the circuit diagram (i.e., inputs: addresses 000 and 001, output: address 030).
I/O Address | ||||
Module Type | Rack | Group | Terminal | Description |
Input | 0 | 0 | 0 | Stop PB (NC) |
0 | 0 | 1 | Start PB | |
0 | 0 | 2 | – | |
0 | 0 | 3 | – | |
Output | 0 | 3 | 0 | Motor M1 |
0 | 3 | 1 | – | |
0 | 3 | 2 | – | |
0 | 3 | 3 | – |
To program the PLC, the devices must be programmed in the same logic sequence as they are in the hardwired circuit (see Figure 3). Therefore, the stop push button will be programmed as an examine-ON instruction (a normally open PLC contact) in series with the start push button, which is also programmed as an examine-ON instruction.
This circuit will drive output 030, which controls the starter.
If the start push button is pressed, output 030 will turn ON, sealing the start push button and turning the motor ON through the starter. If the stop push button is pressed, the motor will turn OFF.
Note that the stop push button is wired as normally closed to the input module. Also, the starter coil’s overloads are wired in series with the coil.
Resource // Introduction to PLC Programming and Implementation—from relay logic to PLC logic
Hi.. Nice Blog..
Just Engg Pvt. Ltd. offer Exclusive Programs with
International Certificates in Industrial Automation, PLC and SCADA
technology.
For Details visit: http://www.justengg.com/
Nice
simple and clear to beginners. cheers!
Thanks Mr Edwards great and simple article,
Thanks you Mr.Edward is very good simply understand a beginner also i am a beginner.
Good info Edvard, many thanks. Portal is great.
Thanks you Mr Edward sir, this portal is very useful especially for us young engineer.
Mr. Edvard sir
please tell to how to learn easily plc programing and suggest me standard book………
good
Very nice article Edvard.
The Best portal
You know what, i am so bless to found this website. Thank you for sharing your expertise.
Jonryl Novicio
Cebu, Philippines
Mr Edvard this portal really an valuable asset for electrical engineers
Thank you Senthil, glad you find EEP usefull!
I am looking for a job in PLC and SCADA programming can you support me. pls do mail me in following mail id
[email protected]
thank you sir…
this site is awesome……. Mr. Edvard u r doing a great job. Thanx
Dear Edward.
I am a 67 year old retired engineer(electrical).I ,recently,by chance saw this portal and read several articles.The first thought came in my my mind was how lucky the young just out of college electrical engineers to have such an wondeful portal with an excellent source of information related to selection,installation,testing,operating and different type of electrical equipments.Now a days to all the young engineers who approach me for guidance and advice,i recommend your portal to be a successful professionalEngineer.Please keep on continuing this for the beneit of the young engineers..Your effortd are highly commendable.May god Bless You Always.
V.Natarajan
Thank you both of you Natarajan and Hemant! That’s very kind of you!
To be honest I put a lot of efforts and years to make EEP usable and recognized place for electrical engineers worldwide. Your compliments confirm this definitely!
Thank you again!
Thank you for the kind words!
This portal is the best which I saw…
Thank you Kolalexnic!
